29640 Discussions
Further problem with using 'interface' for accessing C from Fortran
andy_in_oxford
I have a further problem with accessing C from Fortran. This follows on from my early problem that was solved. The program compiles but crashes on running. I am building and running the following in Windows using the Intel Fortran compiler. My program compiles eccodes.f90 and grib_f90.f90 correctly and grib_copy_msg.f90 compiles correctly. But when I try to run it an error is thrown:
I have the following:
In the top part of the program grib_copy_msg.f90 I have:
program copy
  use eccodes
  implicit none
  integer  :: infile, igrib_in, status
  print *,'I am here 1'
  call codes_grib_new_from_file(infile, igrib_in, status)
  print *,'I am here 2'
In eccodes.f90 there is:
subroutine codes_grib_new_from_file ( ifile, gribid , status)
    integer(kind=kindOfInt),intent(in)              :: ifile
    integer(kind=kindOfInt),intent(out)             :: gribid
    integer(kind=kindOfInt),optional,intent(out)    :: status
    !DIR$ ATTRIBUTES DLLEXPORT :: codes_grib_new_from_file
    print *,'I am here 1.1'
    call grib_new_from_file ( ifile, gribid , status)
end subroutine codes_grib_new_from_file
codes_grib_new_from_file  is in a file called grib_f90.f90:
  subroutine grib_new_from_file ( ifile, gribid , status)
      integer(kind=kindOfInt)                         :: iret
      interface
        integer(c_int) function grib_f_new_from_file(ifile,&
                       gribid) bind(C, name="grib_f_new_from_file_")
          use iso_c_binding, only: c_int
          integer(c_int), intent(in) :: ifile
          integer(c_int), intent(out) :: gribid
        end function grib_f_new_from_file
      end interface
      print *,'I am here 1.2'
      iret=grib_f_new_from_file( ifile, gribid )
      print *,'I am here 1.3'
      if (present(status)) then
         status = iret
      else
         call grib_check(iret,'grib_new_from_file','')
      endif
  end subroutine grib_new_from_file
grib_f_new_from_file is in a C file called grib_fortran.c:
int grib_f_new_from_file_(int* fid, int* gid){
    int err = 0;
    FILE* f = get_file(*fid);
    grib_handle *h = NULL;
    if(f){
        h = grib_handle_new_from_file(0,f,&err);
        if(h){
            push_handle(h,gid);
            return GRIB_SUCCESS;
        } else {
            *gid=-1;
            return GRIB_END_OF_FILE;
    *gid=-1;
    return GRIB_INVALID_FILE;
int grib_f_new_from_file__(int* fid, int* gid){
    return grib_f_new_from_file_( fid, gid);
int grib_f_new_from_file(int* fid, int* gid){
When I try to run it, I get the output:
I am here 1
I am here 1.1
I am here 1.2
The program then crashes.
What mistake have I made with the interface?  I read that I don't need to add an interface in if I use capitals for  GRIB_F_NEW_FROM_FILE, could someone provide an example in this context please?
andy_in_oxford
Thank you Arjen and Jim for your replies on this topic. I have solved this now.
The problem actually was that I hadn't set an environmental variable, the ECCODES_DEFINITION_PATH variable.
jimdempseyatthecove
Experiment by commenting out push_handle in your .c function and see if you make it to 'I am here 2'
If you do, then the problem is within push_handle.
Also, while your file has type .c, is it compiled as C or as C++?  If as C++ then attribute the function with extern "C"
IOW (if C++) while the entry point name can be resolved in C++ using C naming convention (compiler option), the calling API might not be resolved without the appropriate measures taken.
Jim Dempsey
andy_in_oxford
Thanks Jim. I have tried running it with push_handle commented out and it still doesn't reach 'I am here 2'.
It is compiled as 'C'.
Arjen_Markus
Just a few thoughts:
  • Has the argument ifile been given a value?
  • Can you add print statements to the C code to see where in the C function things go poof?
andy_in_oxford
