Generic operators with ABSTRACT derived types such as (*) do not work as expected.
FortranFan
I think the following code is alright but Intel Fortran compiler 17.0 update 1 gives an unexpected error:
module parent_m
   implicit none
   private
   type, public, abstract :: parent_t
      private
   contains
      procedure(Iassign_parent), pass(lhs), deferred     :: assign_parent
      procedure(Ireal_times_parent), pass(rhs), deferred :: real_times_parent
      procedure(Iparent_op_parent), pass(lhs), deferred  :: parent_add_parent
      ! operators
      generic :: assignment(=) => assign_parent
      generic :: operator(+) => parent_add_parent
      generic :: operator(*) => real_times_parent
   end type parent_t
   abstract interface
      pure subroutine Iassign_parent(lhs, rhs)
      !< Operator `=`.
         import :: parent_t
         class(parent_t), intent(inout) :: lhs
         class(parent_t), intent(in)    :: rhs
      end subroutine Iassign_parent
      function Ireal_times_parent(lhs, rhs) result( res )
         !< Operator `real * type`.
         import :: parent_t
         real,            intent(in)  :: lhs
         class(parent_t), allocatable :: res
      end function Ireal_times_parent
      function Iparent_op_parent(lhs, rhs) result( res )
         !< Symmetric operator `type.op.type`.
         import :: parent_t
         class(parent_t), intent(in)  :: lhs
      end function Iparent_op_parent
   end interface
end module parent_m
module child_m
   use parent_m, only : parent_t
   implicit none
   private
   type, extends(parent_t), public :: child_t
      private
   contains
      procedure, pass(lhs) :: assign_parent => assign_child          !< Operator `=`.
      procedure, pass(rhs) :: real_times_parent                      !< Operator `real * type`.
      procedure, pass(lhs) :: parent_add_parent => child_add_parent  !< Operator `+`.
   end type child_t
contains
   pure subroutine assign_child(lhs, rhs)
   !< Operator `=`.
      class(child_t), intent(inout) :: lhs
      return
   end subroutine assign_child
   function real_times_parent(lhs, rhs) result( res )
   !< Operator `real * cons`.
      class(child_t), intent(in)   :: rhs
      allocate ( child_t :: res )
      return
   end function real_times_parent
   function child_add_parent(lhs, rhs) result( res )
   !< Operator `+`.
      class(child_t), intent(in)   :: lhs
      return
   end function child_add_parent
end module child_m
module m
   use child_m, only : child_t
   implicit none
contains
   subroutine sub1( foo, bar )
      class(parent_t), allocatable, intent(inout) :: foo
      class(parent_t), intent(inout) :: bar
      select type ( bar )
         type is ( child_t )
            bar = 0.5 * foo
         class default
      end select
      return
   end subroutine sub1
   subroutine sub2( foobar )
      class(parent_t), intent(inout) :: foobar
      type(child_t) :: foo
      type(child_t) :: bar
      select type ( foobar )
         type is ( child_t )
            foobar = 0.5 * ( foo + bar )
         class default
      end select
      return
   end subroutine sub2
end module m
Upon compilation,
Compiling with Intel(R) Visual Fortran Compiler 17.0.1.143 [Intel(R) 64]...
m.f90
m.f90(34): error #6633: The type of the actual argument differs from the type of the dummy argument.
ifort: error #10298: problem during post processing of parallel object compilation
compilation aborted for m.f90 (code 1)
FortranFan
FWIW, the code in the original post compiles successfully with gfortran.
From what I can see, the instructions in procedure sub2 in module m where the compiler gives an error are equivalent to those in sub1, but sub1 compiles ok.
Steve_Lionel
I've seen this before and am pretty sure I escalated it before I retired. The issue is that the compiler isn't properly recognizing that foo+bar is of a compatible type. A workaround is to do the add to a temp and use that:
      type(child_t) :: temp
      type is ( child_t )
            temp = foo + bar
            foobar = 0.5 * ( temp)
         class default
      end select
      return
   end subroutine sub2
Kevin or one of the other Intel folks can find the escalation and add this report to it.
FortranFan
Steve Lionel (Ret.) wrote:
I've seen this before and am pretty sure I escalated it before I retired. The issue is that the compiler isn't properly recognizing that foo+bar is of a compatible type. A workaround is to do the add to a temp and use that ..
Thanks Steve.  This was actually driven by a discussion on comp.lang.fortran and OP is indeed using the workaround you suggest.
Stefano_Zaghi
Dear FortranFan and Steve,
thank you very much for your help, it is very very appreciated.
As FortranFan said, I am already using the Steve's workaround, that is viable for simple math, but for more complex it becomes somehow unclear.
Is this also an issue for Intel 17.0.2 (update 2)? I am going to update my current update 1...
My best regards.
Steve_Lionel
It is still an issue in 17.0.2.
Kevin_D_Intel
It relates to this post (linked to DPD200413156). That issue is not currently fixed. I added this additional test case to the existing internal tracking id.
(Internal tracking id: DPD200371156)
Stefano_Zaghi
Thank you Steve!
Dear Kevin, thank you too, your help is really appreciated.
Indeed, Francesco and I are working together :-) This is issue occurred to both working to together, but in different projects, thus we were not sure it was due to the same reason. Thank you for the clarification.
My best regards.
Stefano_Zaghi
Dear all,
I have just joined the 2018 beta testing initiative. With the fresh installed parallel studio xe 2018 beta I got the same error
┌╼ stefano@zaghi(01:01 PM Thu Apr 13) desk {intel-18.0.0.beta - Intel Parallel Studio XE 2018.0.0 beta}
├───╼ ~/fortran/compilers_bug/intel_abstract_types_operators 1 files, 12Kb
└──────╼ ifort -c abstract_types_operator.f90
abstract_types_operator.f90(134): error #6633: The type of the actual argument differs from the type of the dummy argument.
compilation aborted for abstract_types_operator.f90 (code 1)
My best regards
Kevin_D_Intel
The internal tracking id linked to that case (DPD200413156) is not fixed yet.
jimdempseyatthecove
Haven't tried this, how about:
     type is ( child_t )
           foobar = 0.5 * ( child_t(foo + bar) ) ! using constructor
        class default
     end select
     return
  end subroutine sub2
Jim Dempsey
Stefano_Zaghi
Dear Jim,
thank you for your suggestion. I do not know why, but I did not received an alert of your message, thus I miss it until now. Later today I'll try it.
My best regards.
jimdempseyatthecove
FWIW, if the error carrot (^) moves from the + to the *, then use
foobar = child_t(0.5 * ( child_t(foo + bar) ) ) ! using two constructors
Jim Dempsey
