29488 Discussions
Getting Intel Fortran & IMSL up and running in VS 2008
maciej
Dears,
I used old IMSL4.0 and other Fortran for a few years so thought it would not take me all day to compile test program now in Intel. I know it is sure obvious for most of you but I spent a few fine hours digging in documentation and internet to get Intel Fortran + IMSL in VS2008 up and running... I think the documentation lack of short and simple part "How to set environment in VS2008 to get Intel Fortran & IMSL working".
So for anyone new who simply might want to compile Fortran source using IMSL - two, also simple steps in VS2008 before pressing F5:
1. Menu Project/[name] Properties: Fortran - set "Additional Include Directories" field to "C:\Program Files\VNI\imsl\fnl600\IA32\include\dll" (this will ensure the first pass will be succesfull but not the linking phase)
2. Menu Project/[name] Properties: Linker/Input - set "Additional Dependencies" field to "C:\Program Files\VNI\imsl\fnl600\IA32\lib\imsl_dll.lib" (this will ensure also linking phase will be succesful)
This is for IA32 systems - I think on x64 should be similar. Also I have to check if I had to use some IMSL/STAT maybe it may require me to make additional changes.
Now I am happy coding my new Intel Fortran with IMSL libraries. :)
best regards,
Maciej
In the right column of this forum (on the main page) is a link to a Knowledge Base article on Installing and Using the IMSL Libraries. This information is provided - it's also in the compiler documentation under Using Libraries.
I'm glad to hear that you figured it out on your own.
maciej
Finally I found it here and in the provided documentation because I didn't stop looking for it after I solved the problem.
I bought the product yesterday and rushed into porting my old F95 codes and thought I do it in two or three clicks... ;)
I see great potential in using this Intel VisualFortran because I always had problems in getting Windows API to work in old Fortran.
Thank You for answering me.
regards,
Maciej
Glad to hear it. Feel free to ask here if you have further questions.
