Go To vs If Statement
chauvjo
I have two questions regarding the following legacy code segment:
      do i=1, n_total, increment
         diff = array(i) - x1
         if (diff < 0.0_dp) then
         !   do something
            go to 10
         else if (diff == 0.0_dp) then
         !   do something
            go to 10
         else if (diff > 0.0_dp) then
         !   do something
            go to 10
         end if
      end do
   ! We fell out of do loop, write error and stop
      write(unit=6,fmt='(''No Match'')')
      stop
   10 continue
1. Does Fortran 1990/95/03/08 provide a specific keyword or state variable (maybe something like END_STATUS) to check if a do loop completes without a branch or break or, in the case above, do you have to check the value of i against n_total?   The first approach would allow a standard set of code which would be independent of the index and terminal variable.
2. In the code above, would it be better to replace the go to statements with break and enclosed the error message in an if statement? Any performance difference between the two approaches?  What would be best practice?  Any other approach would be welcome.
Thanks....
loopblock: block
         !   do something
            exit loopblock
         !   do something
            exit loopblock
         !   do something
            exit loopblock
         end if
      end do
      stop
   end block loopblock
! Execution continues here if something found
chauvjo
Thanks Steve...the BLOCK construct looks great....
mecej4
So far the "how" has been covered, but unless you have more things going on in the DO loop, the "why bother" question applies.
As it is, the DO loop will be executed only once, and the jump taken, because a real variable cannot be anything other than < 0, = 0 or > 0, unless you wish to cover the case where some of the variables involved are undefined.
chauvjo
mecej4...the first conditional should be:
         if (diff < 0.0_dp) cycle
FortranFan
Note under floating-point precision, the following statement is almost meaningless:
[fortran]
[/fortran]
jimdempseyatthecove
mecej4,
The none of the above condition is: (isnan(diff))
FortranFan, (diff == 0.0_dp) almost meaningless
In the O.P's case, exact equality may be desired, chauvjo will have to determine this. In many applications it may be appropriate to use
real(dp), parameter :: AlmostZero = 1.0D-30 ! user specified
         if (diff < -AlmostZero) then
         !   do something
            exit loopblock
         else if (diff > AlmostZero) then
         !   do something
            exit loopblock
         else then
         ! -AlmostZero : AlmostZero
         !   do something
            exit loopblock
         end if
The above assumes NAN is never presented
Jim Demspey
TimP
The code presented has some of the flavor of translation of arithmetic IF.  Perhaps it assumes that abrupt underflow (/Qftz) is set so as to avoid accidental production of subnormals in place of zeroes.
chauvjo
Tim P.: You are correct. The code segment I posed was a translation of an arithmetic IF.
Jim: You have raised another issue on how best to handle an floating point equivalence check in an if statement.  Since this is off topic, I will start a new threat called "floating point equivalence check"
