29653 Discussions
Help with error: RPM std error output
postaquestion
I have download the non-commercial Intel Fortran compiler for Linux (10.1.015), when I installed it, I had this error:
RPM std error output is as follows:
erreur: Dpendances requises:
libstdc++.so.5 is necessary for intel-ifort101015-10.1.015-1.i386
libstdc++.so.5(GLIBCPP_3.2) is necessary for intel-ifort101015-10.1.015-1.i386
This failure occured using the following RPM options:
-U --replacefiles --force
Testing Intel Fortran compiler installed in /opt/intel/fc/10.1.015 ...
--- ERROR ---
Cannot find ifort compiler in /opt/intel/fc/10.1.015/bin
I work on Linux machine (fedora 7) microprocessor Xeon Intel. Please, i will be extremely thankful if you can help me.
Kevin_D_Intel
You have not satisfied the minimum software requirements to install and use the Intel compiler as per the error you received.
Please refer to this Support article for a detailed discussion of this error and how to address it: http://support.intel.com/support/performancetools/sb/CS-026139.htm
To address the error youmust install the required compat-libstdc++ RPM which provides the /usr/lib/libstdc++.so.5 library, and then re-try Intel compiler installation.
Hope that helps.
