29274 Discussions
Help with mixed C++/Fortran under .NET framework
scottgrossman
I've been running a large fortran program under VC++ 6.0 and Compaq Fortran, and was told to investigate what it would take to port to the latest greatest environment.
Along those lines I wrote a little test program, which I dont seem to be able to get working. I've defined a Solution space with 2 projects, the first being a fortran project that generates a static library, the second being a C++ console application that links in the static library.
The sample code is as follows
C++
#include
#include
#include
#include
extern "C" void FORTRANTEST (int *i);
void main(int argc, _TCHAR* argv[])
int i=1;
cout << i << ' ';;
FORTRANTEST (&i);
cout << ' ';
cout << "After calling Fortran routine i= " << i << ' ';;
cout << ' ';
cin >> i;
FORTRAN
subroutine FORTRANTEST (int1)
c ! Expose subroutine Fortran to users of this DLL
!DEC$ ATTRIBUTES DLLEXPORT:: FORTRANTEST
!DEC$ ATTRIBUTES C, ALIAS:'_FORTRANTEST' :: FORTRANTEST
implicit integer (i-n)
int1 = int1 + 1
return
end
The fortran compiles and generates the library, but when I try to link the C++ solution it says theres an unresolved library libIEPCF90.lib. Alright I dont know why it uses this, but I found it and put it in the additional dependencies list, and relinked, and got an error saying the linker couldn't find Program.obj
Any help would be greatly appreciated. Please feel free to e-mail me at sngsmg@aol.com
Scott
isn-removed200637
The following slightly modified version works:
// testprog1.cpp : Defines the entry point for the console application.
#include "stdafx.h"
#include
#include
#include
#include
extern "C" void __stdcall FORTRANTEST (int* i);
int i=22;
cout << i << '
FORTRANTEST (&i);
cout << '
cout << '
cin >> i;
SUBROUTINE FORTRANTEST(int1)
interface
subroutine FORTRANTEST(int1)
!DEC$ ATTRIBUTES C, ALIAS:'_FORTRANTEST@4' :: FORTRANTEST
integer int1
end subroutine FORTRANTEST
end interface
integer int1
int1 = int1 + 1
return
end
Note the '@4' added to the alias name. HTH
isn-removed200637
P.S. The FORTRAN code was used to generate a library
FORTTEST.LIB that was added to the C++ project.
scottgrossman
Anthony,
Thanks for the help, but when I tried to compile this:
interface
integer int1
end subroutine
end interface
integer int1
int1 = int1 + 1
return
end
I get the following errors:
C:Testfortran2fortrantest.f(7): Error 275 : Another entity has the same name as procedure FORTRANTEST specified in the interface block ending here
C:Testfortran2fortrantest.f(10): Error 119 : More than one program entity with this name is accessible
Thanks again
Scott
hweisberg
In the code you pasted in you have
_FORTRANTEST @4'
with an unwanted space before the @4. Could this be the problem?
Major it's just a problem with the software for this forum and you don't actually have an extra space!
scottgrossman
hweisberg,
It appears to be a bug in the forum posting software. Source as written doesnt have the extra space in it.
Scott
isn-removed200637
I hope that it is just the forum software screwing up what I hoped
I had pasted correctly. I notice that in your code,the line beginning
the 'INTERFACE' block has been telescoped onto the line
preceding it. I think 'INTERFACE' should start on a new line.
Try that and I hope it will work for you.
Just to repeat, this is what I programmed
in the FORTRAN STATIC library project:
interface
integer int1
end interface
integer int1
int1 = int1 + 1
return
end
For Steve Lionel, I have had a hell of a job to get the
above message into the form I wanted - I frequently got telescoped lines, added spaces etc - until I cut out
a block of text just before the
code.
ALso, as you see, this block is in BOLD when I have not specified it as such...please can you fix this?
Steven_L_Intel1
I'd like to fix it, but I can't - the forum software is messing up. I have reported it to the appropriate folks.
Steve
isn-removed200637
Got your message.
I have looked at your project files. It appears you are using the Intel compiler, of which I have no knowledge.
I had hoped to find Compaq Visual Fortran workspace (.DSW)
and project (.DSP) files in your zipped archive, but
found none, only .VFPROJ files, of which I have no
experience either. It appears that the Intel compiler is
a different beast.
I use the Compaq Visual Fortran compiler with Visual
studio, which uses the above-mentioned workspace and
project files.
It would appear that the Intel compiler does not recognise
the !DEC$ compiler directives. Also, the FORTRAN code I
posted was in free-format whereas I note your FORTRAN
code is aligned to start in column 7 as if it were fixed-
format. The Compaq compiler recognises code in files
ending .F or .F90 as being in free-format whereas files
ending .FOR are expected to be in fixed-format (starting
in column 7, comments start in column 1). What does the
Intel FORTRAN compiler expect? You will have to ask the
Intel compiler support for help on what their equivalents
are to the !DEC$ compiler directives. I think your problems
lie solely in this area. The FORTRAN and C++ code compile
fine using the VF compiler and MS Visual C++ compiler.
I attach a screen shot of the console (I have tweaked the
program to loop by accepting other +ve non-zero integers as input, terminating with a -ve number).
regards
Tony Richards
isn-removed200637
Well, I tried to attach a file, but the forum software failed miserably to do anything when I pressed the atttach files and post message button, It even failed to respond to the 'go back'edit' button after I had browsed to the file in the edit box. Here goes another try...
Steven_L_Intel1
The formatting problem should be fixed now. Sorry for the inconvenience.
Steve
