29376 Discussions
How do I compile and Link from a DOS command line?
markmerritt
Can anyone refer me to a resource that explains how to compile and link from a DOS window command line? I'd like to know the available options and be able to see examples of how it's done.
Much Thanks!
markmerritt
BTW. I'm using Compaq visual Fortran, version 6.6.
TimP
On your Windows Start menu, you should have a selection with the choice of starting the compiler under GUI or opening a command prompt window where the compiler paths are set up. In that window, your options begin with a simple
DF myhelloworld.f
and run the resulting .exe
One of the strengths of that compiler was relatively good starting advice, which you might consider using.
The CVF Programmer's Guide has an entire chapter on this topic.
