29648 Discussions
How do I continue to another command line?
caodavid
How do I correct the following error?
read(*,'(A)') filename
open(UNIT=lu, FILE=filename, STATUS='OLD', ACTION='READ',&
ISOSTAT=ierror)
C:My DocumentsFortranexer_4least_squares_fit.for(29) : Error: Syntax error, found '&' when expecting one of: * ...
open(UNIT=lu,FILE=filename,STATUS='OLD',ACTION='READ',&
What should I use instead of ?&? if I want to continue on another line?
(Visual Fortran 5.0, FORTRAN f90)
james1
The ampersand is valid only for free source format. Make sure you are not using fixed or tab source formats. If your source has a type of .FOR try using .F90 instead.
James
