I have developed an agent based model for the penetration of new technology into the automarket. Some of my analyses will require multiple runs to generate appropriate statistics. Depending on the number of agents employed in the model, the run time can be quite long for each. It would be quite nice to run the model from a batch file multiple times. However, my executable requires some input from the keyboard each run, e.g. Are you introducing Car A or Car B.
Question: Can I run my *.exe file from a batch file which would also provide the normal keyboard input?
Thank you!
John
Thank you!
John
I supopose You are using console application.
Long time ago I put keyboard input into my FORTRAN executables through text files:
let say I have text file keyboard.txt containing:
car a
testit
carb
then I run program.exe < keyboard.txt
and each time program.exe uses "read(*,*) variable"
it obtains from keyboard.txt text (or value) "car a", "testit" and "carb".
I hope it helps
Jakub Zlamal
car a
testit
carb
I hope it helps
Jakub Zlamal
Quoting - irenejohn@aol.com
Thank you!
John
Thank you!
John
Would a normal argument list do the job?
Look up GETARG in the help file for more informations.
Markus
Or better, the standard GET_COMMAND_ARGUMENT.
Or have I missed something?
John
John
Yes, that you can convert a string to a number using internal READ (and the other way round using internal WRITE).
Jugoslav
