29635 Discussions
How to handle a runtime specified file in the program
paulgerard
Using the /fpscomp:filesfromcmd option I can specify which file should be opened by the program.
Running f.e. MyProg.exe Test.Out opens test.out on the first Open statement.
But in this way the program only opens the file, allowing to read, write, delete etc by unit number. How to proceed if my program must actually handle the file name, f.e. producing derived files like Test1.out, test2.out, test3.out. Then in some way the actual filename must be accessible within the program. Maybe using getArg?
hweisberg
Do you mean something like
open(6, File='Test.dat', RECORDTYPE='STREAM')
Look at the GETOPENFILENAME example program.
Steve
