29488 Discussions
How to output a matrix without changing to a new line?
Tai_Q_
For example
program main
integer m
complex cjj
complex matrix(3, 5)
cjj=(0.0, 1.0)
matrix(1, :)=2*cjj
matrix(2, :)=2+1*cjj
matrix(3, :)=5*cjj+6
open(16, file='data.txt')
do m=1, 3
write(16, *)matrix(m, :)
enddo
close(16)
end
The above code does not work well. What I want is that the data in the output file is the same as the dimension of the matrix.
For this case, the size of the matrix is 3*5. What I want is also there are 3 lines ,and each line has 5 values.
mecej4
Do not use list-directed WRITE when you require the output to be formatted in a certain way. The following will work with IFort for your program above:
     write(16, '(*(F5.1,2x,F6.2))')matrix(m, :)
Tai_Q_
Thanks so much,
Even though I have been using Fortran for many years. I still do not familiar with the Fortran output/input format. Could you please tell me, how to make the output of a complex number like:
(1.69E-004,4.06E-007)
Tai
