How to pass c array to fortran dll
yan__san-chi
First I create Fortran  subroutine below:
module showarr
use, intrinsic :: iso_c_binding
implicit none
private
public calltest
contains
subroutine calltest(a,b) bind(C,name = "calltest" )
    implicit none
    real(c_double),intent(in), dimension(*) :: a
    real(c_double),intent(in) :: b
    real,  parameter::pi=3.14159
    integer :: i
    real :: sum = 0.0
    do i = 1,3
        sum = sum+a(i)
    end do
    write(*,*) 'total',sum
    write(*,*) 'Hello World',b*b*pi
    return
end subroutine calltest
end module showarr
I want to pass array a  and a number b in C program, return summed array  elements  and circle of area with radius b.
And my C program:
#include "stdafx.h"
#include <iostream>
using namespace std;
extern "C" {
	// Prototype for the Fortran Function
	double calltest(double [],double );
int main(){
	double a[] = { 2.0, 1.5, 3.0};
	double r = 3.0;
	cout << endl;
	cout << "call dll output " << calltest(a,r) << endl;
	system("pause");
	return 0;
Ran C code, I got following error list:
Error    1    error LNK2019: unresolved external symbol _calltest referenced in function _main    C:\Users\astro\Documents\Visual Studio 2013\Projects\vc\fordll_ex2\fordll_ex2\fordll_ex2.obj    fordll_ex2
Error    2    error LNK1120: 1 unresolved externals    C:\Users\astro\Documents\Visual Studio 2013\Projects\vc\fordll_ex2\Debug\fordll_ex2.exe    1    1    fordll_ex2
Would someone can help me? Thanks!
IanH
The !DEC$ thing in #2 just exports the symbol, which won't conflict with the standard BIND(C) stuff.
(There's no need for the Fortran to be in a DLL separate to the C++ code - you could make a static library out of the Fortran stuff and then link that static library with your C++ code to get an executable with both the C++ and Fortran in it.)
In #2, the Fortran source defines a subroutine, while the C++ code declares calltest as a function returning double.  To match a Fortran subroutine, the C++ declaration should be `void calltest(...` - i.e. the equivalent of a C++ function that doesn't return anything.
(Or, if you actually want the Fortran thing to return a double, then it needs to be a Fortran function.)
yan__san-chi
After referenced Standard Fortran and C Interoperability, the problem solved.
Modified Fortran code:
module showarr
implicit none
private
public calltest
contains
subroutine calltest(a,b) bind(C,name = "calltest")
!DEC$ ATTRIBUTES DLLEXPORT :: calltest
    implicit none
    real(c_double), dimension(*),intent(in):: a
    real(c_double),intent(in),value :: b
    integer :: i
    real :: sum = 0.0
    do i = 1,3
        sum = sum+a(i)
    end do
    return
end module showarr
Modified C code:
#include "stdafx.h"
#include <iostream>
extern "C" {
	double calltest(double a[],double b);
int main(){
	double a[] = { 2.0, 50, 3.0};
	double r = 5.0;
	cout << endl;
	system("pause");
	return 0;
 The output of conscole:
 total   55.00000
 Hello World   78.5397529602051
call dll output -1.#IND
What is "call dll output -1.#IND"? Does it can be removed?
mecej4
It is a bad idea to mix "legacy interoperability", i.e., DEC$ directives, with ISO Fortran-C interoperability.
By default, Fortran passes arguments by reference. Your C routine, the way you wrote it, expects the second argument to be passed by value, and interprets the address on the stack as a double precision number, causing a wreck. The prototype should be ..., double *b).
IanH
yan__san-chi
Oh! I am stupid I forget it is subroutine. Thank you for your reminding.
