29656 Discussions
How to read a character string in memory as integer bytes?
anthonyrichards
New Contributor III
I have successfully tried the IVF Encrypt/Decrypt samples on a character string held in a text file. Both programs take a source file and read the data into a buffer using unformatted READ, filling an integer buffer equal in length toa number of bytes in the file (the buffer is defined as INTEGER(BYTE) and pointed to by a pointer generated using MALLOC). After encryption/decryption, the result is written using unformatted WRITE to a destination text file.
What I am looking for is a way to modify the programs to replace thesource and destination text files by character strings in memory. Can anyone advise me of a way todothis? I am apparentlyforbidden from using internal unformatted READ/WRITES.
You don't need to "read" the data - it's already in memory. Just pass LOC(string) and LEN(string), assuming the length is less than the algorithm's blocksize. If it's just a single string, there's not much else to do other than worrying about padding. If it's multiple strings then you probably know how long each one is supposed to be.
anthonyrichards
New Contributor III
Thanks, Steve, I will try that, which is much simpler than the fudge I found to work, namely:
EQUIVALENCE an INTEGER(1) ISTRING(256) to a CHARACTER(256) STRING
and then fill the INTEGER(1) BUFFER using
ICOUNT=0
....(some other stuff if a key-blob is written...)
DO I=1,LENGTH
ICOUNT=ICOUNT+1
BUFFER(ICOUNT)=ISTRING(I)
END DO
