29341 Discussions
How to remove NUL character from end of variable in output file
Bakhbergen
I am using yamajun's program to get MAC ADDRESS by Fortran:
https://software.intel.com/en-us/forums/intel-fortran-compiler/topic/299146
https://fortran66.hatenablog.com/entries/2008/02/28
https://software.intel.com/en-us/forums/intel-fortran-compiler/topic/297960
Sending the results to output *.txt file
WRITE (18,'(8A)') AdapterInfo(i)%IpAddressList%IpAddress, AdapterInfo(i)%IpAddressList%IpMask
gives the following:
0.0.0.0NULNULNULNULNULNULNULNULNUL0.0.0.0NULNULNULNULNULNULNULNULNUL
XXX.XXX.X.XXXNULNULNULXXX.XXX.XXX.XNULNULNUL
where X denotes different numbers.
I would like to see only addresses in the file. Please advise how to remove null string characters.
Arjen_Markus
You will have to replace the NUL characters by, say, spaces - or if the length of the addresses is constant, you could write a substring instead.
Most general:
function removenuls( string)
   character(len=*) :: string
   character(len=len(string)) :: removenuls
   integer :: pos
   pos = index( string, achar(0) )
   if ( pos > 0 ) then
       removenuls = string(1:pos)
   else
       removenuls = string
   endif
end function removenuls
It does assume that there are no meaningful characters after the first NUL, but that is generally the case with strings coming from C. An alternative to achar(0) is the c_null_char parameter from ISO_C_BINDING.
Steve_Lionel
Really the right way to do this is to use INDEX to find the first NUL, use that to compute the length of the actual text, and write only the substring. Don't rely on characters following the first NUL to be anything specific.
Bakhbergen
Arjen, Steve, thanks. I've tried the following:
WRITE (18,'(8A)') AdapterInfo(i)%IpAddressList%IpAddress(1:INDEX(AdapterInfo(i)%IpAddressList%IpAddress, ACHAR(0))-1), AdapterInfo(i)%IpAddressList%IpMask(1:INDEX(AdapterInfo(i)%IpAddressList%IpMask, ACHAR(0))-1)
which causes the following errors:
*.f90(119): error #6514: A substring must be of type CHARACTER.   [IPADDRESS]
*.f90(119): error #6362: The data types of the argument(s) are invalid.   [INDEX]
*.f90(119): error #6514: A substring must be of type CHARACTER.   [IPMASK]
Arjen_Markus
You should use INDEX(AdapterInfo%lpAddressLIst^%lpAddress,ACHAR(0) ) -1 as the end value, Note the location of the -1.
Steve_Lionel
FWIW, I wrote a proposal for Fortran 202X that would make dealing with C strings easier.
Paul_Curtis
Valued Contributor I
The following code, abstracted from a larger program, accomplishes what the OP asked for:
MODULE MAC
    USE ifwinty
    USE charfunc
    IMPLICIT NONE
    PUBLIC GetMacInfo
    PRIVATE
    SAVE
    INTEGER, PARAMETER :: MAX_ADAPTER_DESCRIPTION_LENGTH = 128
    INTEGER, PARAMETER :: MAX_ADAPTER_NAME_LENGTH        = 256
    INTEGER, PARAMETER :: MAX_ADAPTER_ADDRESS_LENGTH     =   8
    INTEGER, PARAMETER :: MIB_IF_TYPE_ETHERNET           =   6  ! Ipifcons.h
    TYPE IP_ADDRESS_STRING
        CHARACTER(LEN=16) :: String
    END TYPE IP_ADDRESS_STRING
    TYPE IP_MASK_STRING
    END TYPE IP_MASK_STRING
    TYPE t_IP_ADDR_STRING
        INTEGER (LPLONG)         :: pNext
        TYPE (IP_ADDRESS_STRING) :: IpAddress
        TYPE (IP_MASK_STRING)    :: IpMask
        INTEGER (DWORD)          :: Context
    END TYPE t_IP_ADDR_STRING
    TYPE t_IP_ADAPTER_INFO
        INTEGER(LPLONG)         :: pNext
        INTEGER(DWORD)          :: ComboIndex
        CHARACTER(LEN=MAX_ADAPTER_NAME_LENGTH+4)        :: AdapterName
        CHARACTER(LEN=MAX_ADAPTER_DESCRIPTION_LENGTH+4) :: Description
        INTEGER(UINT)           :: AddressLength
        INTEGER(BYTE)           :: Address(MAX_ADAPTER_ADDRESS_LENGTH)
        INTEGER(DWORD)          :: Index
        INTEGER(ULONG)          :: iType
        INTEGER(ULONG)          :: DhcpEnabled
        INTEGER(LPLONG)         :: pCurrentIpAddress
        TYPE(t_IP_ADDR_STRING)  :: IpAddressList
        TYPE(t_IP_ADDR_STRING)  :: GatewayList
        TYPE(t_IP_ADDR_STRING)  :: DhcpServer
        INTEGER(BOOL)           :: HaveWins
        TYPE(t_IP_ADDR_STRING)  :: PrimaryWinsServer
        TYPE(t_IP_ADDR_STRING)  :: SecondaryWinsServer
        INTEGER(ULONG)          :: LeaseObtained
        INTEGER(ULONG)          :: LeaseExpires
    END TYPE t_IP_ADAPTER_INFO
    !   must link with IpHlpApi.lib to access this API function;
    !   this interface is not included in ifwinty
    INTERFACE
        INTEGER(BOOL) FUNCTION GetAdaptersInfo (arg1, arg2)
            USE ifwinty
            !DEC$ ATTRIBUTES DEFAULT, STDCALL, DECORATE, ALIAS:'GetAdaptersInfo' :: GetAdaptersInfo
            INTEGER(LPLONG) :: arg1
            INTEGER(LPLONG) :: arg2
        END FUNCTION
    END INTERFACE
CONTAINS
    SUBROUTINE GetMacInfo (hwnd, id)
        USE contwrap
        IMPLICIT NONE
        !   dialog window handle and set of static-text IDs for display
        INTEGER(HANDLE), INTENT(IN)         :: hwnd
        INTEGER, INTENT(IN), DIMENSION(4)   :: id
        CHARACTER(LEN=200)                  :: msg
        INTEGER                             :: i, nc, count
        INTEGER, PARAMETER                  :: acount = 16
        TYPE(t_IP_ADAPTER_INFO),ALLOCATABLE :: ai(:)
        count = 0
        !   allow for multiple adapters
        ALLOCATE (ai(acount))
        nc = SIZEOF(ai)
        IF (GetAdaptersInfo(LOC(ai), LOC(nc)) == 0) THEN
            DO i = 1, acount
                SELECT CASE (ai(i)%iType)
                CASE (MIB_IF_TYPE_ETHERNET)
                    !   line 1: description and MAC address
                    !nc = INDEX(ai(i)%Description, CHAR(0)) - 1
                    !WRITE (msg, '(A,",  ",5(Z2.2,"-"),Z2.2)') &
                    !    ai(i)%Description(1:nc),              &
                    !    ai(i)%Address(1:ai(i)%AddressLength)
                    msg = ai(i)%Description(1:nc)
                    count = count + 1
                    CALL StaticSetText (hwnd, id(count), msg)
                    CALL ControlSetVisible (hwnd, id(count), .TRUE.)
                    !   line 2: IP and Gateway addresses
                    WRITE (msg, '("IP Addr: ",A,"  Gateway: ",A)')  &
                        ai(i)%IpAddressList%IpAddress%string,       &
                        ai(i)%GatewayList%IpAddress%string
                    CALL remove_nulls (msg)
                    count = count + 1
                    IF (count >= 4) EXIT
                END SELECT
                IF (ai(i)%pNext == NULL) EXIT
            END DO
        END IF
        DEALLOCATE (ai)
    END SUBROUTINE GetMacInfo
END MODULE MAC
JohnNichols
Valued Contributor III
In the Intel Fortran Forum -- I get an error on trying to post a new topic
Old form please resubmit
I have rebooted and done a scannow and it still happens -- I am not sure if this work as I have tried many times - so I posted to the MKL as well
This is my last go -- fingers crossed
any ideas?
jimdempseyatthecove
On 5/11/20 I experienced several dropped contacts with the IDZ forums (aliens screen) . A few times after composing a lengthy post. I am in the habit of copying post to paste buffer before clicking on Submit, so I don't lose my effort. In one or two minutes connection is reestablished and I can re-post via paste buffer.
Jim Dempsey
Bakhbergen
I appreciate everyone's effort in helping to resolve this.
After a few more attempts last week, I decided to leave it as it is because I found that NULs disappear when *.txt file is open using Notepad and WordPad.
Note that earlier I was using Notepad++, which shows some NULs in the output *.txt file.
GVautier
New Contributor III
NULL characters doesn't disappear they just are not shown. With Notepad++, you can choose to show special characters or not. See in the display menu for special characters item.
Bakhbergen
Vautier, Gilles wrote:
Bakhbergen
Gilles, sure, you're right. I should probably have written that NULs "disappear" when *.txt file is open using Notepad and WordPad with default settings.
