29657 Discussions
How to remove this error (ifort: internal error: error generating temporary file name)
Anonymous21
Hi... I have some problem.
If compiling my code, this message appears:
-----> ifort: internal error: error generating temporary file name(shared/driver/hostutil.c, line 311)
I never see this error beforecompiling my code for the same situation. Could you let me konw how to solve it?
Please report the problem to Intel Premier Support and include the makefile or commands you're using to compile as well as the source file in question.
Anonymous21
If I install and update linux, this problem does not occur. But if I only install linux without update of Linux and after then, fortran complier is setup,this situation makethis kind of error. However, I do not know why this problem happens.
The problem needs to be investigated by support engineers. Please file a support request and include as many details as you can.
Lorri_M_Intel
This problem is related to your /tmp directory.
Please make sure the protection is set writeable - and for some strange reason - executable.
If you are using the environment variables TMP, TMPDIR, or TEMP to define your temporary storage area, check those directories instead.
- Lorri
