How to resolve this error
learning_mode_2004
I'm using intel_fc_80 copiler to compile fortan programs using ifort command on linux platform.I'm getting the following error.Any pointers to remove these errors would be highly welcome.
fortcom: Error: aababc.f, line 145: A specification expression object must be a dummy argument, a COMMON block object, or an object accessible through host or use association [NMECI]
COMMON /XYIJKL/ XY(NMECI,NMECI,NMECI,NMECI)
fortcom: Error: aababc.f, line 146: A COMMON block data object must not be an automatic object. [OCCA]
COMMON /BASEOC/ OCCA(NMECI)
Following are the lines(145,146) which are the source of errors
Do i need to make changes to the above lines in order to compile the above two lines without nay errors?I'm sure of making some changes.
TimP
NMECI would have to be specified as a constant (normally in a PARAMETER statement) prior to use in those declarations.
