29641 Discussions
How to use execute_command_line cmdmsg
Matt_Thompson
All,
I'm hoping you can help with this. I just tried this simple program:
program test
   implicit none
   integer :: estat, cstat
   character(len=255) :: cmsg
   estat = -999
   cstat = -999
   cmsg  = "notfilled"
   call execute_command_line("/bin/cp ~/yayay ~/alskalkd", &
      exitstat=estat, cmdstat=cstat, cmdmsg=cmsg)
   write (*,*) 'estat: ', estat
   write (*,*) 'cstat: ', cstat
   write (*,*) "cmsg:  ", trim(cmsg)
end program test
Nothing too fancy or anything. I do not have a file called "yayay" in my home, so I expected to see cmdmsg to have something and yet:
(276) $ ifort -V
Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0.0.098 Build 20160721
Copyright (C) 1985-2016 Intel Corporation.  All rights reserved.
(277) $ ifort test.F90 && ./a.out
/bin/cp: cannot stat ‘/home/mathomp4/yayay’: No such file or directory
 estat:            1
 cstat:            0
 cmsg:  notfilled
So, we see that cp failed (as it should) but cmdmsg was never changed. I suppose I'm wondering, given the standard:
CMDMSG (optional) shall be a default character scalar. It is an INTENT (INOUT) argument. If an error condi-
tion occurs, it is assigned a processor-dependent explanatory message. Otherwise, it is unchanged.
have I encountered the dreaded "processor-dependent" result of nothing? EXITSTAT seems to have been set to non-zero (which is the return status of the cp call), but...no cmdmsg.
IanH
No - in this context an error condition refers to something that prevents the command from being executed  - for example if `/bin/cp` didn't exist.  See the description of CMDSTAT.
In your example, `/bin/cp` was able to be executed - so CMDSTAT is zero, CMDMSG is unchanged, and EXITSTAT has been defined with the exit status of `/bin/cp`, as expected.  It is up to your program to interpret that EXITSTAT.
Matt_Thompson
Okay, let's say I change my program to:
   call execute_command_line("/bin/alsdjfasjdflasjdfa", &
Now, let's see:
(284) $ /bin/alsdjfasjdflasjdfa
/bin/alsdjfasjdflasjdfa: Command not found.
(285) $ ifort test.F90 && ./a.out
sh: /bin/alsdjfasjdflasjdfa: No such file or directory
Segmentation fault (core dumped)
Ummm...is that expected?
From what I can tell, with the latter command line the "system" command used by EXECUTE_COMMAND_LINE doesn't return. I don't get a segmentation fault, just a hung program.
Matt_Thompson
I guess that's better than a core dump. I suppose until all compilers support EXECUTE_COMMAND_LINE, it's sort of a moot point, but I'd really love to get rid of the tangle of ifdefs I have in Fortran those programs that use system. At least iargc and its brethren are no longer needed...
Does it work ok for valid commands?
Matt_Thompson
It does. Our thought here was we were seeing some issue with a system call that wasn't working, but the output/error was being suppressed or moved away some how. Luckily for us, the commands we are issuing are more like the first style (bad cp) so that we can rely on exitstat to test for issues.
I was just really hoping cmdmsg worked in all errors. I love IOMSG so much and it's so useful, that anything like it I will use!
As Ian says, CMDMSG only tells you if there was an issue executing the command, not anything about what the command itself does. In fact, it would have no way of interpreting the exit status.
