29592 Discussions
How to use ifort command with visual studio ?
Guizzh
I've downloaded Microsoft visual studio 2019 and intel fortran compiler (my computer uses windows 10). I open the files in visual studio and I open the powershell developper. When I enter "ifort *.f90", in order to compile every .f90 files in the folder, I get the following message :
"ifort :  the term "ifort" is not recognized as the name of a cmdlet, function, script file, or executable program."
What can I do to avoid this problem ?
Steve_Lionel
If you're using Powershell, do this.
  1. Use the shortcut Intel installed in the Start menu under Intel oneAPI 2021 > Intel oneAPI command prompt for Intel 64
  2. Type "powershell".
Now you can use the ifort command. Of course, you can skip step 2 if you like. Just be sure to change your directory ("cd") to your work area.
JohnNichols
Honored Contributor I
You can also change the start directory in the properties for the start menu shortcut to point to a different folder, but it fails with subst drives.
Guizzh
Thank you for your answer.
I used "Intel OneAPI command prompt for intel 64 for visual studio 2019", typed "powershell" and changed the directory but sadly it still doesn't work and I get the same message
Steve_Lionel
You get the SAME message? Please show us a log of the session. Also note that *.f90 will not work - you need to name the files. If you are building multiple files, a Visual Studio project is easier.
Guizzh
Yes, the same message.
That's what I get, in english it would mean : "ifort :  the term "ifort" is not recognized as the name of a cmdlet, function, script file, or executable program. Check the spelling of the name, or if a path exists, verify the path is correct and try again."
I tried to compile it with *.f90 but I don't think that this is the problem.
Steve_Lionel
Show me the whole thing - like this:
I wonder if you have the compiler properly installed.
Guizzh
I set visual studio up again and it seems to work.
Thank you for your help !
