29649 Discussions
Huge program, need to force declarations
grg99
HI, I have this relatively huge program, about 40,000 lines in 183 source files.
I've found lots of errors in the source code caused by arguments that don't match the subroutine dummy argument type.
But the compiler doent find many of these by itself, as none of the subroutines had interfaces (to start out with). I'm building up interfaces as I go along, but the task is error-prone-- if I forget to add "use glue" to a subroutine, it will silently compile anyway and generate bad calls.
It sure would be nice if the compiler required interfaces for every called function or subroutine.
Is there some fortran option to require these?
grg
If you're using Intel Fortran, yes.
/gen-interface /warn:interface
