Hi, Steve,
I just installed the latest IVF9.1 (extension -025)and the VS2005. Since I have to install both IA32 and EM 64for integrating the compilet to VS2005, how do I know the one integrated is the EM64 (which is what I want), not the IA32? My operation system is Windows XP(64 version).
regards
Chang
The compiler you use is determined by the target platform you select. If you select a target of x64, you get the EM64T compiler.
Steve,
Thank you. But how do I select the target platform when I install the compiler? I did not see an option.
regards
Chang
You don't select it when you install - by default, you get both the IA-32 and EM64T compiler on install (if you have a suitable version of Visual Studio or the PSDK.)
See the Building Applications manual section on VS projects for details on how to select the target platform. It isn't obvious.
Topic Options
