The following code generates an ICE with the Intel classic Fortran compiler 2023 ifort:
type :: con_type
class(*), allocatable :: value
end type
interface con_type
procedure :: constructCon
end interface
type(con_type), allocatable :: a(:)
a = [con_type([1, 2]), con_type(1)]
contains
function constructCon(value) result(con)
class(*), intent(in) :: value(:)
type(con_type) :: con(size(value))
integer :: i
do i = 1, size(value)
con(i)%value = value(i)
end do
end function
end
Here is the error message:
/app/example.f90(1): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for /app/example.f90 (code 1)
The source of the ICE is line number 17, where the function output is declared as an automatic array:
then the error is resolved. Is this code standard compliant?
I asked one of the Fortran compiler team; he represents Intel at the Fortran standards committee. He says your code is legal and I should file a bug. I did that already.
There are a few things that don't seem right to me about your example but I will leave that to other with more expertise in this area. Anyway an ICE is a bug irrespective of if the code is good or bad. My other motive is seeing if I can actually post after the forum update.... I nearly said "upgrade" but that would need more evidence.....
Yes, the Forums are working again. The security update to the login took longer than planned.
I filed a bug report on this, COMPLRLLVM-44906. So glad you found a workaround!
Thanks for taking the extra step to check the standard compliance. The new portal looks great and is better than the old interface.
This ICE is resolved in ifx that was released this week. It's part of oneAPI 2023.2 HPC Toolkit. Please check it out.
fantastic! thank you.
