29657 Discussions
ICE with IFX using procedure pointers
mhulsen
The attached file gives an ICE with ifx, version: (IFORT) 2023.0.0 20221201. The output is at the end of this message.
Note, that it is a very much reduced code starting from a large code and maybe it can be reduced even further, but at least it gives the same error message as the large code.
It compiles fine with ifort, gfortran and nagfor.
Martien
The output is:
[tfemuser@080a0116f9cd ifx-ice]$ ifx -c ifx-ice.f90
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1f563ca]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1bef70e]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1c55e52]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1c55e26]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1b69946]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1b6f2d1]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1b73215]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1be1b73]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1be09c3]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1ca3eed]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1ca4500]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1ca6a30]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1ca19c2]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1ca104a]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1b44bf6]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1b445c9]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1d028ee]
/lib64/libc.so.6(+0x27510)[0x150e660e4510]
/lib64/libc.so.6(__libc_start_main+0x89)[0x150e660e45c9]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1982da9]
ifx-ice.f90(75): error #5623: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
    call evaluate_scalar_coefficient ( func=coefficients%func1(3)%p )
compilation aborted for ifx-ice.f90 (code 3)
Ron_Green
Thanks for finding this and reporting.  I'll open a bug report.
Ron_Green
Bug ID is CMPLRLLVM-43357
martinmath
Below is a short reproducer, which is by the look of it, caused by the same bug in ifx, causing an ICE.
program proc_pointer
type :: t
   procedure(answer), nopass, pointer :: p
end type t
type(t) :: x
x%p => answer
call foo(x%p)
contains
   function answer() result(x)
      integer :: x
      x = 42
   end function answer
   subroutine foo(a)
      procedure(answer) :: a
      print *,a()
   end subroutine foo
end program proc_pointer
mhulsen
The bug seems to be fixed in 2023 update 1. My finite element code of near 100000 loc passes all my tests with ifx now.
Thanks for the fix.
Martien
Barbara_P_Intel
I added the new reproducer to the bug report. Sometimes these bugs are tricky and may not have the same cause. We will see!
Ron_Green
this bug is fixed in the 2024.0 release
