ICE with OpenMP workshare construct
Harald
the following code leads to an internal compiler error:
module ifc_openmp_workshare_bug
  implicit none
  type t
     real, pointer :: u(:,:)
  end type t
contains
  subroutine sub (z, x, y)
    real,    intent(out) :: z(:,:)
    type(t), intent(in)  :: x
    type(t), intent(in)  :: y
!$omp parallel workshare
    z = x%u * y%u
!$omp end parallel workshare
  end subroutine sub
end module ifc_openmp_workshare_bug
% ifort -V -c -fopenmp ifort_omp.f90
Intel(R) Fortran Compiler XE for applications running on IA-32, Version 15.0.5.223 Build 20150805
Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
FOR NON-COMMERCIAL USE ONLY
 Intel(R) Fortran 15.0-1818
010101_13492
catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for ifort_omp.f90 (code 1)
Harald
Lorri_M_Intel
Kevin - This was repaired in 16.0 under tracking id DPD200370580.
Harald - thanks for your report, especially the nice compact example.
The fix was not ported back to the 15.0 stream, but there is a workaround if you're not able to upgrade.
Change this line:
 z = x%u * y%u
to this:
 z(:,:) = x%u(:,:) * y%u(:,:)
    Thanks --
           --Lorri
Kevin_D_Intel
Thank you for reporting this internal error. It appears we already have a fix in our latest 16.0 compiler. I we see whether I can track down any past internal tracking id associated with an explicit fix.
$ ifort -V
Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.0.109 Build 20150815
$ ifort -c -qopenmp u596039.f90
Lorri_M_Intel
Change this line:
 z = x%u * y%u
to this:
    Thanks --
           --Lorri
Kevin_D_Intel
Thank you Lorri!
Harald
Lorri,
thanks for pointing out a quick workaround.  By playing around I found that it can even be shortened to
    z(:,:) = x%u * y%u
to avoid the ICE.  :-)
Harald
Change this line:
 z = x%u * y%u
to this:
    Thanks --
           --Lorri
