Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
ICE with allocated() on not allocatable member
Greetings again,
i got an internal compiler error with the following (wrong) code:
module test_mod
  type T_BAR
    integer :: a(1)
  end type
contains
  subroutine foo(this)
    class(T_BAR), intent(in) :: this
      if(allocated(this%a)) then
      end if
  end subroutine
end module
Intel Fortran Compiler: 16.2
Wolf
Highlighted
Thanks. Escalated as issue DPD200408692.
Retired 12/31/2016
Highlighted
Fixed for the major release later this year. The compiler will now give an error for this incorrect usage.
Retired 12/31/2016
