29036 Discussions
ICE with ifx 2025.0.4 [regression]
Juergen_R_R
Valued Contributor II
The following code, when compiled in two different files, gives an ICE with ifx 2025.0.4, but was working fine in ifx 2024.
ifx -c repro.f90; ifx -c repro_sub.f90
repro_sub.f90(13): error #5623: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
int_out%parents = int_in%parents
Submodule file:
submodule (interactions) interactions_s
  implicit none
contains
  !!! ICE function
  module subroutine interaction_assign (int_out, int_in)
    type(interaction_t), intent(out) :: int_out
    type(interaction_t), intent(in), target :: int_in
    !!! ICE
    if (allocated (int_in%parents)) then
       allocate (int_out%parents (size (int_in%parents)))
    end if
  end subroutine interaction_assign
end submodule interactions_s
Main file:
module interactions
  implicit none
  type :: internal_link_list_t
     private
     integer, dimension(:), allocatable :: link
  end type internal_link_list_t
  type :: interaction_t
     private
     type(internal_link_list_t), dimension(:), allocatable :: parents
  end type interaction_t
  interface assignment(=)
     module procedure interaction_assign
  end interface
  interface
  end interface
end module interactions
(Virus scan in progress ...)
Igor_V_Intel
Thank you for sharing a small reproducer for this bug. It is still in the latest build of the compiler. I escalated it to the development team to be fixed.
Igor_V_Intel
-nostandard-realloc-lhs may help (is a workaround) to avoid this compiler crash
Juergen_R_R
Thanks for the workaround, but the -nostandard-realloc-lhs was sort of trauma around and before 2016/2017. I'm happy not to have to use this anymore. So I'll wait for the (hopefully timely) fix.
