ICE with valid code
MR
The following code produces an ICE with ifort 15.0 Build 20150407 (on Linux Intel(R) 64)
$ ifort -c testice.f90
testice.f90(50): warning #6178: The return value of this FUNCTION has not been defined.   [RES]
 elemental function met1(f) result(res)
testice.f90(44): warning #6178: The return value of this FUNCTION has not been defined.   [RES]
 elemental function cnt_met1(f) result(res)
testice.f90(38): warning #6843: A dummy argument with an explicit INTENT(OUT) declaration is not given an explicit value.
 elemental subroutine to_ta(y,x)
testice.f90: catastrophic error: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for testice.f90 (code 1)
module m1
 implicit none
 type, abstract :: c_base
 contains
  private
  generic, public :: method => met1
  procedure(i_met1), pass(f), deferred :: met1
 end type c_base
 type, extends(c_base) :: t_cnt
 contains
  private
  procedure, pass(f) :: met1 => cnt_met1
 end type t_cnt
 type, extends(c_base) :: t_a
 contains
  private
 end type t_a
 abstract interface
  elemental function i_met1(f) result(res)
   import :: c_base, t_cnt
   implicit none
   class(c_base), intent(in) :: f
   type(t_cnt) :: res
  end function i_met1
 end interface
 interface assignment(=)
   module procedure to_ta
 end interface
contains
  type(t_cnt), intent(in)  :: x
  type(t_a),  intent(out) :: y
 end subroutine to_ta
  class(t_cnt), intent(in) :: f
  type(t_cnt) :: res
 end function cnt_met1
  class(t_a), intent(in) :: f
  type(t_cnt) :: res
 end function met1
end module m1
module m2
 use m1
 implicit none
 type :: t_g
  type(t_a), allocatable :: aa(:,:), bb(:)
 end type t_g
contains
 subroutine s()
  integer :: i
  type(t_g) :: a
  allocate( a%aa(1,3), a%bb(3) )
  a%aa(1,:) = a%bb%method() ! ICE
  do i=1,3
    a%aa(1,i) = a%bb(i)%method() ! works
  enddo
 end subroutine s
end module m2
Thanks - I can reproduce this and will escalate it to the developers. Even if the code was not valid, an internal compiler error is never appropriate. Issue ID is DPD200374956.
MR
Steve, thank you.
Just to check my complete case from which this test was derived, why do you say that the code is not valid?
I didn't say the code is not valid.  What I was trying to get across was that an ICE is never an acceptable response, no matter whether the code is valid or not.
As far as I can tell, your code is fine.
MR
Ah, thank you for clarifying, then I misunderstood your comment.
As for the ICE, yes, I understand that it should be always reported, both for valid and invalid code.
Marco
I expect this problem to be fixed in Update 2, scheduled for February.
