28496 Discussions
IFX 2023.0.0 ICE using varible format expressions on Windows
fortrandave
Greetings,
Please consider the following code which generates an ICE in IFX but works fine in Classic 2023.0.0.  Can this be fixed in the next point release?
! Examples work fine in Classic using::
! Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on
! Intel(R) 64, Version 2021.8.0 Build 20221119_000000
! Examples that produce ICEs with IFX using:
! Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version
! 2023.0.0 Build 20221201
! xfortcom: Fatal: There has been an internal compiler error (C0000005).
module mymodule_m
implicit none
contains
subroutine incarray_file(width, iitems, iplaces)
integer, intent(in) :: width
integer, intent(in), optional :: iitems, iplaces
real :: array(8)
integer :: items, places
items  = size(array)
places = 2
601	format(z<width>.<width>) !Comment for ICE 1
602	format(o<width>.<width>) !Comment for ICE 1
603	format(f<width>.<width>) !Comment for ICE 1
if(present(iplaces))then
    write(*, '(<items>(f0.<iplaces>,","))')array !Comment for ICE 2
else
    write(*, '(<items>(f0.<places>,","))')array
endif
if(present(iitems))then
    write(*, '(<iitems>(f0.<iplaces>,","))')array(1:items) !Comment for ICE 3
else
    write(*, '(<items>(f0.<places>,","))')array(1:items)
endif
end subroutine incarray_file
end module mymodule_m
program variable_format_ice
implicit none
end program variable_format_ice
Dave
Barbara_P_Intel
Thanks for reporting this and for the great reproducer. It also ICEs on Linux.
I filed a bug on your behalf, CMPLRLLVM-45008. I'll keep you posted on its progress to a fix.
fortrandave
Again, you're welcome!  And thanks RE the reproducer.  I worked at trying to make it small and self-contained.  Of the three recent issues I posted, this one has the most impact so I'm looking forward to a fix.  I'm expecting I'll be able to compare my ifx compiled application against classic results later this year.
I'll watch this thread for updates.
andrew_4619
Rather than using the non standard format with <width>  when not make some std Fortran. A simple function that build an allocatable string that has been build from the function parameters would be one  way of doing it.
Barbara_P_Intel
I just successfully compiled this reproducer with ifx 2024.0 that was released this week. @fortrandave, please try this updated compiler.
fortrandave
Thanks for the update -- that's great news!  Congrats on the 2024.0 release!
