29647 Discussions
IFX Internal Compile Error (ICE) with system_clock
DataScientist
Valued Contributor I
The following code yields an ICE with the latest IFX:
use iso_fortran_env, only: real128
real(real128) :: count_rate
call system_clock(count_rate = count_rate)
print *, count_rate
end
ifort and gfortran both handle this code gracefully. Here is an example error message: https://godbolt.org/z/zb7vxdjac
Devorah_H_Intel
This issue has been reported before here
The fix will be in the next release.
Devorah_H_Intel
