IFX openmp dependence
DataScientist
Valued Contributor I
From the most recent webinar recordings on Intel ifort and ifx, I realize that ifx automatically enables the OpenMP flag. Does this mean that any software distribution built with ifx requires the Intel runtime environment (for the OpenMP shared files) as well?
Steve_Lionel
My tests show that there is no dependency on OpenMP libraries unless you use OpenMP things.
Steve_Lionel
Barbara_P_Intel
In the webinar, Ron mentioned that for ifx -qopenmp-simd is ON by default at –O1 and above. So if you use OpenMP SIMD directives they are automagically used. To disable those, use -qno-openmp-simd.
Similar thing for ifort except -qopenmp-simd is ON by default at –O2 and above.
Link info in the Fortran Developer Guide.
