29375 Discussions
IMSL 6.0 with Visual Fortran Composer XE 2013 SP1 Upd. 3
Torsten_K_
Hi there,
I can not run the older version of IMSL 6.0 (Package w_fcompxe_imsl_2013.0.002) with the new Composer XE 2013 SP1 Upd. 3. I just achieve to link it with the new version 7 (package w_fcompxe_imsl_2013_sp1.0.024). I wanted to use IMSL v6 cause I wanted to try out something. Even I deinstalled the MSL 7and newly installed version 6. All directory settings are right (Tools > options > Intel Composer XE > Vuiasual Fortran > Compilers, include and libraries), anyway, I get for any call of IMSL-function an unresolved external from the linker. Does IMSL V6 not run with the new Compiler?
Thanks for info.
Torsten_K_
Hi again, problem is solved, I used the wrong verison of IMSL. I needed to install the w_fcompxe_imsl_2013_sp1.0.003-package, then it runs.
