IMSL routines use
joe_s_1
I am supposedly running Visual Fortran Composer XE with IMSL routines on a stand-alone PC. I do not see to have access to the IMSL routines. How could I verify if I indeed have these routines on my PC? Any help would be welcome here. Many thanks, Joe S.
mecej4
To me it is not clear as to what you mean by "..I do not have access to the IMSL routines".
Here are some items whose presence may tell you something about whether IMSL is or had been installed on your system.
Have you checked whether you have entries in the Windows Start Menu with names such as VNI, IMSL or Roguewave in them? Do you have environment variables starting with "FNL_"? Do you have a directory in the standard location, "C:\Program Files (x86)\VNI"? If so, what files do you find there?
If you have a license for Fortran with IMSL the IMSL install is separate from the compiler install. For more information on how to configure your system to use IMSL, see
