29277 Discussions
IMSL with IVF Compiler - license error
Emanuel_C_
I recently installed ISML with a student license to use with IVF. I did everything as explained in these two links:
-https://software.intel.com/en-us/articles/installing-and-using-the-imsl-libraries
-http://docs.roguewave.com/imsl/fortran/7.1/pdf/imslfnl7-1_gettingstarted-windows.pdf
However, when I build the project I obtain the following errors:
Error error LNK2019: unresolved external symbol sprintf referenced in function l_open_license_file imsls_err.lib(check_license.obj)
Error error LNK2019: unresolved external symbol __iob_func referenced in function l_open_license_file imsls_err.lib(check_license.obj)
Any hints on how to solve it?
Steve_Lionel
You are using an IMSL not purchased from Intel. Please contact RogueWave for help with configuring their version of IMSL. The IMSL Intel sells does not use run-time licensing.
