IOSTAT 30 got me stumped
DavidWhite
Valued Contributor II
Having problems with accessing some files, getting IOSTAT 30.
INQUIRE(FILE=TRIM(LICFILE_LOC)//"\\"//TRIM(MName)//".lc", NUMBER=I, IOSTAT=iresult)
If (Logopen) WRITE(99,'(A,I4,I4)') TRIM(LICFILE_LOC)//"\\"//TRIM(MName)//".lc"//" is attached to unit ",I,Iresult
INQUIRE(UNIT=2, NAME=attachedfile, IOSTAT=iresult)
If (Logopen) WRITE(99,'(A,I4)') "UNIT 2 is attached to file "//TRIM(attachedfile),Iresult
Open (2,FILE=TRIM(LICFILE_LOC)//"\\"//TRIM(MName)//".lc",STATUS="OLD", &
ACTION="READ",SHARE="DENYWR",IOSTAT=I)
IF (logopen) WRITE(99,'(A,I4)') "Open "//TRIM(LICFILE_LOC)//"\\"//TRIM(MName)//".lc", I
F:\\AIPS Web\\Model Download Logs\\AWAPROPS.lc is attached to unit -1 0
UNIT 2 is attached to file 0
Open F:\\AIPS Web\\Model Download Logs\\AWAPROPS.lc 30
So file is not attached, unit number is not in use, but when I attempt to open the file, I get IOSTAT 30.
Only explanation is that someone else has the file open, I think.
David
mecej4
Check using the Task Manager if the same (or a related) application was run earlier but has not been properly terminated. If you find the culprit, you may terminate it if you are the only person managing that process.
DavidWhite
That didn't help, but some extra write statements did:
F:\AIPS Web\Model Download Logs\AWAPROPS.lc is attached to unit -1 0
UNIT 1 is attached to file \\model2.alcoa.com\Model_Log$\AWAPROPS.lc 0
Open F:\AIPS Web\Model Download Logs\AWAPROPS.lc 30
The file was attached through a share, but not by the direct name, so INQUIRE did not think the file is attached!
David
