29488 Discussions
IVF 12.0 Compiler Error when '-check all' used with character substring asignment
xin_xu
I started to use the IVF 12.0 on Linux today to compile my fortran programs. I met the following error:
[xxu2@dlxlogin1 test]$ make
ifort -c -g -check all test.F90
0_12307
warning #13003: message verification failed for: 5623; reverting to internal message
: catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for test.F90 (code 1)
make: *** [all] Error 1
The problem will go away if I don't use '-check all' option.
The source code contains a line that asigning a character substring a new value: string(1:1) = 'c'. Without this asignment, the compiler error will go away. Here is the test code:
! test.F90
program main
character(2) :: string
character(1) :: c
c = 'a'
string(1:1) = c !this is the problem line
end
Here is the compile line:
Thanks in advance for any help!
Xin
Would you please show the output of "ifort -V" ? Thanks.
Ron_Green
Xin,
I have tested this code will all versions of the 12.0 compiler. It compiles without error and without warnings for me.
What version of the compiler are you using? ifort -V
The message catalog errors may indicate that you are using a non-English LOCALE for your linux - if so, to what language have you set your system?
Can you attach the file to this issue? Perhaps the code you have has non-visible characters in the file. Can you create a new file, cut and paste the code from above, and try again?
And you do 'source /compilervars.sh intel64' command to set up the compiler?
ron
xin_xu
Steve and Ron,
Thanks for your reply! here is the ifort -V message:
[xxu2@dlxlogin1 test]$ ifort -V
Intel Fortran Intel 64 Compiler XE for applications running on Intel 64, Version 12.0.3.174 Build 20110309
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
I opened up a new file with 'vim test1.F90' then type in the test code and save it. The same compilation error accurs for me. Here is what 'locale' returns:
[xxu2@dlxlogin1 test]$ locale
LANG=en_US.iso885915
LC_CTYPE="en_US.iso885915"
LC_NUMERIC="en_US.iso885915"
LC_TIME="en_US.iso885915"
LC_COLLATE="en_US.iso885915"
LC_MONETARY="en_US.iso885915"
LC_MESSAGES="en_US.iso885915"
LC_PAPER="en_US.iso885915"
LC_NAME="en_US.iso885915"
LC_ADDRESS="en_US.iso885915"
LC_TELEPHONE="en_US.iso885915"
LC_MEASUREMENT="en_US.iso885915"
LC_IDENTIFICATION="en_US.iso885915"
LC_ALL=
I don't know how the compiler is setup. It is done by our system administrator. I could refer this thread to him and ask for his help on that.
Xin
xin_xu
Here are the files.
Thanks!
Xin
Hmm - not seeing it. Can you run the commands exactly as I have them below (you can use test.f90 as the name) and show the output?
[sblionel@f90srv34 ~/project]$ cat t.f90
program main
character(1) :: c
c = 'a'
end
[sblionel@f90srv34 ~/project]$ ifort -c -g -check all t.f90
[sblionel@f90srv34 ~/project]$ ifort -V t.f90
Intel Fortran 12.0-1291
GNU ld version 2.15.92.0.2 20040927
xin_xu
Problem solved!
Our system administrator identified a precedence confilict with the locale string between the new 12.x and the old 11.x versions.
Thanks again for all the valuable comments!
BTW, I want to abuse here a little bit by redirecting to another thread that I created but have no response yet. Sorry for my selfishness!
subject: Stream IO returns wrong file position
http://software.intel.com/en-us/forums/showthread.php?t=82113
Xin
Interesting. Can you elaborate on this conflict? It may be something we want to look at.
I'll take a look at your other thread.
xin_xu
I forwarded your question to our system administrator who resolved this issue and here I quote what he said:
"In the NLSPATH env var, defined in our own env module, we were picking up the previous 11.x locale string before the new 12.x string."
I don't realy understand what this means. But it sounds like the problem is due to our system setup. Hope this helps.
Xin
It does, thanks.
