29611 Discussions
Ifort (Intel Fortran Compiler) for Linux Installtion
Ying
I want to install Intel Fortran Compiler for linux on my Ubuntu 18.04. The default software package downloaded from official website includes many components and takes up 18.1G...Considering my pc has limited space, I just want to install part of these components as long as I can debug Fortran code in GUI. Could anyone give me some idea about what kind of components are necessary for fortran debugging? I would be very appreciated! All the default components include:
Intel Trace Analyzer and Collector 2020 Update 2                  308MB
        Intel Trace Analyzer for Intel(R) 64 Architecture                 78MB
        Intel Trace Collector for Intel(R) 64 Architecture               126MB
    Intel Cluster Checker 2019 Update 9                                  220MB
        Cluster Checker                                                  137MB
    Intel VTune Profiler 2020 Update 2                                   2.1GB
        Command line interface                                           1.2GB
        Sampling Driver kit                                                4MB
        Graphical user interface                                         1.5GB
        Platform Profiler                                                342MB
    Intel Inspector 2020 Update 2                                        355MB
        Command line interface                                           215MB
        Graphical user interface                                          55MB
    Intel Advisor 2020 Update 2                                          1.0GB
        Command line interface                                           424MB
        Graphical user interface                                         783MB
        Flow Graph Analyzer                                              189MB
    Intel C++ Compiler 19.1 Update 2                                     1.3GB
        Intel C++ Compiler                                               1.1GB
    Intel Fortran Compiler 19.1 Update 2                                 593MB
        Intel Fortran Compiler                                           438MB
    Intel Math Kernel Library 2020 Update 2 for C/C++                    3.2GB
        Intel MKL core libraries for C/C++                                11MB
        Cluster support for C/C++                                         12MB
        Intel TBB threading support                                       69MB
        PGI* C/C++ compiler support                                       12MB
        GNU* C/C++ compiler support                                       90MB
    Intel Math Kernel Library 2020 Update 2 for Fortran                  3.0GB
        Intel MKL core libraries for Fortran                               6MB
        Cluster support for Fortran                                        7MB
        GNU* Fortran compiler support                                    171MB
        Fortran 95 interfaces for BLAS and LAPACK                         33MB
    Intel Integrated Performance Primitives 2020 Update 2                4.3GB
        Intel IPP single-threaded libraries: General package             1.4GB
        Intel IPP multi-threaded libraries                               2.0GB
    Intel Threading Building Blocks 2020 Update 3                        153MB
        Intel TBB                                                        124MB
    Intel Data Analytics Acceleration Library 2020 Update 2              4.2GB
        Intel Data Analytics Acceleration Library 2020 Update 2          2.2GB
    Intel MPI Library 2019 Update 8                                      1.1GB
        Intel MPI Benchmarks                                               2MB
        Intel MPI Library for applications running on Intel(R) 64        1.1GB
Architecture
    GNU* GDB 8.3                                                         226MB
        GNU* GDB 8.3 on Intel(R) 64                                       93MB
        Source of GNU* GDB 8.3                                            91MB
        Python sources                                                    26MB
    Intel(R) Distribution for Python*                                    6.4GB
        Intel(R) Distribution for Python* 3 for Linux*                   3.8GB
   Install space required: 18.1GB
   Download space required:  2.8GB
Steve_Lionel
You need only the Intel Fortran Compiler component. There are two versions of the installer - one that has everything (and you then select which parts you want), and one that is small, asks you which components you want and it downloads only those pieces.
You also need g++ installed, if you don't already have it.
Steve_Lionel
Ying
Steve, many thanks for your reply! I have installed ifort successfully!
