29348 Discussions
Import statement failes. Compiler bug?
Robert_van_Amerongen
New Contributor III
The following code fails (Update 1, 2016.0.1.51; both 32 bits and 64 bits.)
  MODULE ti_mod
  USE ISO_C_BINDING
  IMPLICIT none
  PRIVATE
  INTEGER,PUBLIC,PARAMETER :: GLintptr = C_INTPTR_T
  PUBLIC :: glBsd
  POINTER :: glBsd
  INTERFACE
    SUBROUTINE glBsd(tg) BIND(C)
!  The following two lines let the compilation fail:
    IMPORT :: GLintptr
    INTEGER(KIND=GLintptr),VALUE :: tg
!  If the preceeding lines are replace by the following ones, everything wents fine.
!  USE ISO_C_BINDING
!  INTEGER(KIND=C_INTPTR_T),VALUE :: tg
    END SUBROUTINE glBsd
  END INTERFACE
  END MODULE ti_mod
Our gfortran friends do not complain! A compiler bug, I guess?
Thanks - escalated as DPD200380354. Another way around this is to use an abstract interface, which is how I like to declare procedure pointers. For example:
  MODULE ti_mod
  USE ISO_C_BINDING
  IMPLICIT none
  PRIVATE
  PUBLIC :: glBsd
  PROCEDURE(glBsd_Int), POINTER :: glBsd
  ABSTRACT INTERFACE
    SUBROUTINE glBsd_Int(tg) BIND(C)
    IMPORT :: GLintptr
    END SUBROUTINE glBsd_Int
  END INTERFACE
  END MODULE ti_mod
New Contributor III
Steve, thanks for the suggestion.
