29651 Discussions
Incorrect RECL when opening a scratch file
davidgraham
I have just upgraded from cvf to ivf and am getting an error opening a scratch file.
"The error message is forrtl: severe (104) incorrect RECL = specifier value for connected file, unit 61, file ...."
The code is shown below, sometimes it works, sometimes it doesn't. It was OK in cvf, maybe its a security issue with Windows 7. Any suggestions what the problem is.
OPEN (15,FILE=ctrg,ACCESS='DIRECT',form='binary',RECL=30)
OPEN (17,FILE=CCON,ACCESS='DIRECT',form='binary',RECL=12)
open (61,STATUS='scratch',access='direct',form='binary',recl=14)
open (62,STATUS='scratch',access='direct',form='binary',recl=30)
open (63,STATUS='scratch',access='direct',form='binary',recl=8)
open (64,STATUS='scratch',access='direct',form='binary',recl=4)
mecej4
From the Intel Fortran Reference Manual (boldface added), under
OPEN: RECL Specifier:
For fixed-length records, RECL indicates the size of each record; it must be specified. If the records are unformatted, the size must be expressed as an even multiple of four.
I hope someone else can explain why "multiple of eight" was not used instead of "even multiple of four", or if "even multiple" simply means "integer multiple".
TimP
I didn't see whether the question was about RECL specified in bytes or according to the CVF default of multiples of 4.
If possible, it might be worth while to convert this stuff to standard Fortran syntax. For ifort to preserve all non-standard behaviors of CVF is a lot to ask.
davidgraham
I found the solution, it was because the file had been opened previously in another option with a different record length. For some reasom with cfv I didn't need to close/delete it. I have now added
close (61,status='DELETE')
and it is OK.
