Incorrect output
vzecca
The following program produces an incorrect output.
Runs fine if compiled with gnu gfortran
! ifort produces incorrect computation on initialization expression
! must be compiled and run
character(len=3), parameter :: e(2,3) =
1 reshape([(repeat(achar(i),3),i=iachar('a'),iachar('a')+2*3-1)],
2 shape(e))
character(len=3), parameter :: f1(2,3) = eoshift(e,1) !this is bad
character(len=3) :: f2(2,3)
f2 = eoshift(e,1) !this is good
print '(6a3)',f1
print '(6a3)',f2
if(any(f1/=f2)) stop "compiler error!"
end
Can anybody look into it?
andrew_4619
I compiled with Intel® Visual Fortran Compiler - extension version 19.1.0055.15, Package ID: w_comp_lib_2020.1.216. F1 and F2 were the same. What version did you use and what compile options?
andrew_4619
Actually I will qualify as I just looked at f1 and f2 in the debugger and they are the same. The problem comes with ( f1 /= f2 )
f1 and f2 are the same with alternate null strings  ifort returns ( "null string" /= "null string" ) as true.  I don't know what the standards say but maybe that expression is undefined behaviour.
    Program testy
        character(len=3), parameter :: e(2,3) =reshape([(repeat(achar(i),3),i=iachar('a'),iachar('a')+2*3-1)],shape(e))
        logical          :: logi(2,3)
        print '(6a3)',f1
        print '(6a3)',f2
        logi = (f1 /= f2 )
        if( any(f1/=f2) ) print *,"compiler error!"
    end
Further digging, I am wrong. F1(2,1) contains 000000 hex whilst f2(2,1) has 202020 ( space char)
So in summary the parameter eoshift zeros the new elements and the variable assignment fills them with space character. That seems like a bug to me.
vzecca
Andrew_4619, I have ifort 19.1.2.254 under Linux Fedora 32.
Did you try the same program with another compiler, say gnu gfortran.
With gfortran the code runs just fine.
vzecca
With ifort I get
bbbdddfff
bbb   ddd   fff
while with gfortran I get
bbbdddfff
bbbdddfff
as it should be.
andrew_4619
Yes if you read the last line of my previous post, that is crux of the matter. In ifort one initialisation sets the string memory locations to zero and the other sets it to three space characters. This seem like a bug to me. File a ticket with support. You could simplify the test case a bit further
vzecca
I did open a ticket, number 04793750, but Intel rejected it,
because I only have a 30 days license.
If an Intel engineer reads this, please do something.
andrew_4619
To be honest that sucks big time and seems to be the norm. If that is indeed a bug and I believe it is one, I would expect a vendor to log it irrespective of if you have support or not. You are not asking for support just giving up the error.
    Program testy
       character(2), parameter  :: e(2)  = [ 'aa','bb' ]
       character(2), parameter  :: f1(2) = eoshift(e,1)
       character(2)             :: f2(2)
       f2 = eoshift( e, 1 )
       print '(Z4.4)', transfer( f1(2), 0_4 ) ! prints 0000
       print '(Z4.4)', transfer( f2(2), 0_4 ) ! prints 2020
    end program testy
 I will submit a ticket for the test case above:
edit : Your Support request number is 04795094
vzecca
Andrew, running your testy program with ifort I get
0000
2020
with gnu fortran I get
2020
I think my original code is a better test case.
andrew_4619
The bug report is for ifort. The bug is that f1 and f2 do not have the same data. The reproducer is minimalist and demonstrates the problem.  Irrespective of that, the ticket also has a hyperlinks to the forum thread as background.
andrew_4619
This was accepted as invalid compiler behaviour and logged as CMPLRIL0-33239
vzecca
Thank you for the help, Andrew.
