I have a quick question (maybe a compiler bug?) regarding vectorization. I am playing with the following code piece:
Declaration of variables:
1415 real(kind=8), allocatable :: F(:), dF(:) 1416 real(kind=8) :: value
Loop that is being vecotirzed:
1486 do k = ks, ke 1487 do ii = iis, iie 1488 value = vals(ii) 1489 do j = js, je 1490 ind_offset = ( (k-1)*N2 + (j-1) ) * N1g 1491 ioffset = ii + ind_offset 1492 do i = is, ie 1493 dF(i + ind_offset) = dF(i + ind_offset) + value * F(i + ioffset) 1494 end do 1495 end do 1496 end do 1497 end do
Vectorization report for the inner loop (Line 1492 to Line 1494):
src/ModDeriv.f90(1492): (col. 15) remark: loop was not vectorized: existence of vector dependence. src/ModDeriv.f90(1493): (col. 17) remark: vector dependence: assumed ANTI dependence between line 1493 and line 1493. src/ModDeriv.f90(1493): (col. 17) remark: vector dependence: assumed FLOW dependence between line 1493 and line 1493. src/ModDeriv.f90(1493): (col. 17) remark: vector dependence: assumed FLOW dependence between line 1493 and line 1493. src/ModDeriv.f90(1493): (col. 17) remark: vector dependence: assumed ANTI dependence between line 1493 and line 1493.
I compiled the code using ifort 13.1.0 with -O2 -vec-report6. From the vectorization report, the compiler could not vectorize the inner loop (Line 1492 to Line 1494). The compiler was failing to recognize that the inner loop is the same situation as
dF( i ) = dF( i ) + v * F( i )
which should be no different than
A( i ) = B( i ) + c * D( i )
all of which are vectorizable. Any suggestions?
Thanks for your time and help.
Wentao
Not sure, probably an oversight by the compiler optimization gurus.
TimP mentioned in a different thread that the optimizer will at times re-order and/or collapse the loop nesting when it thinks the performance would be better. This is a good test case where it is not.
Jim Dempsey
In front of your DO i loop insert:
!DEC$ SIMD
Jim Dempsey
!DEC$ SIMDJim Dempsey
Hi Jim,
Thanks for your reply. I could vectorize the loop by adding !DIR$ SIMD in front of the DO i loop. Actually I am just curious why the compiler is so conservative in face of such an easy loop:-)
Wentao
Jim Dempsey
Jim Dempsey
Hi Jim,
Thanks for your reply. I found if I only had one inner loop (not multi-level loop), the compiler could vectorize the code without !DIR$ SIMD:
1486 k = ks 1487 ii = iis 1488 value = vals(ii) 1489 j = js 1490 ind_offset = ( (k-1)*N2 + (j-1) ) * N1g 1491 ioffset = ii + ind_offset 1492 do i = is, ie 1493 dF(i + ind_offset) = dF(i + ind_offset) + value * F(i + ioffset) 1494 end do
So it should be the loop nesting that led to this issue. Thanks!
Wentao
