29611 Discussions
Install Intel fortran compiler for Linux
PF59
Hi,  I was provided with the website and downloaded the following package:: Intel® Parallel Studio XE Professional Edition for Fortran and C++ Linux*.  I then installed using the "install.sh" and the installation went smoothly since I chose all the defaults.  BTW, there is another installation file, "install_GUI.sh".  I did not run the _GUI file.
I tried to compile and run a test fortran file, which  I was able to run on another machine with ubuntu/Intel fortran compiler, but it fails.  The new laptop does not recognize what "ifort" command is.
Have I achieved my goal: install the fortran compiler in my ubuntu machine?  Or  what have I installed?  Where can I see the installed files? Is there anything I still need to do?
PF59
mecej4
PF59
I followed the instructions.  Did the following:
source compilervars.sh intel64
source /opt/intel/parallel_studio_xe_2018/bin/psxevars.csh intel64
Then I generated a local fortran test file, "hello.f90"
print *," Hello"
end
ifort -o hello hello.f90
The following error messages showed up:
ld: cannot find -lm
ld: cannot find -lpthread
ld: cannot find -lc
Anything I missed in configuring the installation?
jimdempseyatthecove
