I am trying to install the fortran compiler on Snow Leopard. Everything seems to go fine until I get to the summary, where it tells me "The installation failed." I have no indication what the problem could be. It spends time saying files are being written, but nothing in /Developer seems to change.
Update: I redownloaded the package and used the license file that was emailed to me instead of typing in the activation code myself. Now the installation is successful. I don't know if the problem was I needed to use the license file, or maybe my previous download was corrupted. I also did more exploring into the custom download location to discover it's installed to /opt/intel, not /Developer.
Glad you read you successfully installed the compiler and determined the default installation location. Its unclear what might have caused the initial install failures. Our apologies for the inconvenience.
Quoting - Kevin Davis (Intel)
By default, the compiler tries to create a license file directory under /Users/Shared/Library/Application Support/Intel/Licenses.
Some applications change permissions on /Users/Shared/Library/Application Support/ and remove write priviledge. This could be the cause.
