I currently have IVF v 9.1.3427.2003 installed in XP-Pro using VC++ .net standard v 2003. How do I install same in Windows 6/64?
Don't?
Ok, let's try again. First, you will need VS2005 at a minimum. We never supported version 9.1 of the compiler on Windows 7 but it will probably install ok if you have VS2005. You will need to install VS2005 SP1 and the VS2005 Update for Windows Vista. See http://msdn2.microsoft.com/en-us/vstudio/aa948853.aspx for more info.
