29422 Discussions
Installed to AUS notebook with Windows 8 compiler does not work
Alexander_T_1
I have installed Intel Compiler for Windows v.10 to ASUS notebook with OS Windows 8.1.
IT does not work. When I try to run some simple program (chit.f90)
The message was the following
LINK:  fatal error LINK1104: cannot open file "chit.exe"
If I click on ifort.exe and try to run the compiler from the command prompt window appear the following message
"The program can't start because mspdb80.dll is missing from your computer. Try to reinstall the program to fix this problem."
I reinstalled compiler two times with the same result.
Kevin_D_Intel
