29377 Discussions
Installing Fortran compiler on CentOS 5.3
oafrumento
I'm trying to install fortran compiler (11.1.046) on a CentOS 5.3 (64) linux box and step 4 reports:
Step no: 4 of 7 | Installation configuration - Missing Optional Pre-requisite
There is one or more optional unresolved issues. It is highly recommended to fix
it all before you continue the installation. You can fix it without exiting from
the installation and re-check. Or you can quit from the installation, fix it and
run the installation again.
Missing optional pre-requisite
-- cannot determine operating system type
-- system glibc or kernel version not supported or not detectable
How can I deal whit these issues?
CentOS should be similar to Red Hat Enterprise Linux.
Kernel version:
2.6.18-128.el5
Thanks a lot,
oscar
TimP
If you installed g++ in the linux install package selection menu, glibc-devel should have been installed automatically. If either of those are missing (in the g++ -m32 flavor if you are trying to install ifort ia32), you could expect this message.
rpm -qa glibc would show whether glibc was installed by rpm (the expected way).
oafrumento
Quoting - tim18
following glibc packages have been installed:
glibc-2.5-34.i686
glibc-2.5-34.x86_54
glibc-common-2.5-34.x86_64
glibc-devel-2.5-34.i386
glibc-devel2-5-34.x86_64
glibc-headers-2.5-34.x86_64
kernel-headers-2.6.18-128.el5.x86_64
rpm -qa glibc reports:
glibc-2.5-34
TimP
So it looks like all the glibc versions are there, and by inference, both flavors of g++ ought to be there. If g++ -print-search-dirs and g++ -m32 -print-search-dirs are working, it doesn't look like the installer is justified in complaining. If it's simply complaining about a newer minor version of glibc than the one it was tested with, that's a bug, although CentOS isn't tested for compatibility. I suppose, you should be able to accept the supposed discrepancy and complete the installation. I'm fairly certain I've installed on what ought to be a matching Red Hat version, without seeing that particular complaint.
Ron_Green
Quoting - tim18
If I remember, Fedora/RHEL/CentOS also need libcompat, read about this here:
http://software.intel.com/en-us/articles/using-intelr-compilers-for-linux-under-fedora/
and check that the 32bit stdc++ compatibility library is installed, should be an rpm similar to the FC9 rpm compat-libstdc++-33-3.2.3-63.i386
worse case, try the silent installation http://software.intel.com/en-us/articles/intel-compilers-for-linux-version-111-silent-installation-guide/
oafrumento
well, it seems libraries and dependencies are installed.
Have checked in http://software.intel.com/en-us/articles/using-intelr-compilers-for-linux-under-fedora/; here the version in glibc (for fedora 9) is 2.8-3.i686, while centos 5.3 installed glibc-2.5-34 (quite similars both libraries).
Now, what to do: ignore discrepancies and continue with installation (suggestion 1) or proceed whit "silent installation" (suggestion 2)?
Ron_Green
Quoting - oafrumento
Ignore dependencies and continue with manual installation.
ron
oafrumento
ron
silent installation successful.
thanks a lot.
additional advices?
oscar
Ron_Green
thanks a lot.
additional advices?
oscar
Test both 64 bit and 32 bit compilers. Assuming you have a hello.f90 simple program
source /opt/intel/Compiler/11.1/056/bin/ifortvars.sh intel64
ifort -o hello hello.f90
./hello
source /opt/intel/Compiler/11.1/056/bin/ifortvars.sh ia32
./hello
both should work.
oafrumento
./hello
./hello
both should work.
it's ok.
both compilers work.
thanks again.
regards.
oscar
craig_henryyale_edu
Thanks a lot,
oscar
mv /etc/redhat-release /etc/ORIG.redhat-release
echo "Red Hat Enterprise Linux Server release 5.3 (Tikanga)" > /etc/redhat-release
this will clear up both the reported operating system and the glibc issue
(note the pathing on glibc dirs also contains redhat labelling)
this workaround is also useful for other installs such as Dell OpenManage
Kevin_D_Intel
What's the value in doing this when one can proceed with the installation anyway?
