Is it possible to have IVF 8.0 and 10.1 coexist within Visual Studio? I already have 10.1 installed - how do I integrate the older version (which I need due to some legacy code) into VS 2005?
After installing IVF 8.0 I still only see one choice (10.1) among the compilers in Tools -> Options -> Intel Fortran -> Compilers.
Thanks in advance for your help,
Olivier
Olivier
8.0 does not support VS2005. Also, when you install a version of the compiler integration, it will support a limited number of earlier compiler releases. I think in the case of 10.1 that would go back to 9.0 only.
8.0 supported VS2002 and VS2003.
Quoting - Steve Lionel (Intel)
Argh. Thanks Steve. Do you think it is possible to have VS2003 and VS2005 coexist on the same machine?
Olivier
Sure - no problem.
