Integrating idb into Eclipse
sameguy
Hello everybody,
since the gui frontend to idb seems to be relatvely unstable to me, i want to integrate idb into my eclipse ide.
Is there any way to do this? I already tried including idb into a small script and then invoking that, but it did not work.
Do you have any other ideas that could have me integrating it? I am using Photran Helios, latest version, my idb
version is 10.0.025.
thanks in advance for your advice
This is on Windows? You are probably aware that we are no longer supplying idb on Windows and version 10.0 is no longer supported.
sameguy
No this is on Ubuntu. I can also add an error description. There seem to be some seqfaults also in the mix: There are some more too. Ah ok you said version 10.0 is no longer supported. That is unfortunate for me.
Thanks anyway.
~"Intel Debugger for applications running on IA-32, Version 10.0-30 caught signal "Segmentation fault" (11).\n"
~"This is an unexpected condition and may indicate the presence of a defect.\n"
~"If you wish to report this, please include the stack trace that follows.\n"
~"[0x4001d400]\n"
~"/usr/lib/libstdc++.so.5(_ZNSi4syncEv+0x5d) [0x402dedfd]\n"
~"/usr/local/soft/intel/idb/10.0.025/bin/iidb(_ZN9FilterBuf4syncEv+0x4c) [0x8895e12]\n"
~"/usr/lib/libstdc++.so.5(_ZNSi4syncEv+0x60) [0x402dee00]\n"
~"/usr/local/soft/intel/idb/10.0.025/bin/iidb(_ZN10FilterBaseD2Ev+0x52) [0x8896d9a]\n"
~"/usr/local/soft/intel/idb/10.0.025/bin/iidb(_ZN11FilteredIOSD0Ev+0xd1) [0x8896f1f]\n"
~"/usr/local/soft/intel/idb/10.0.025/bin/iidb(_ZThn108_N11FilteredIOSD0Ev+0xf) [0x8897069]\n"
~"/usr/local/soft/intel/idb/10.0.025/bin/iidb() [0x8881785]\n"
~"/usr/local/soft/intel/idb/10.0.025/bin/iidb(_Z11parseStringPKcN7Session4ModeEb+0x48) [0x8881494]\n"
~"/usr/local/soft/intel/idb/10.0.025/bin/iidb(_Z20parseStringAsCommandPKcN7Session4ModeEb+0x18) [0x8881444]\n"
~"/usr/local/soft/intel/idb/10.0.025/bin/iidb(_Z14MiFortranparsev+0xcc62) [0x89ae716]\n"
~"/usr/local/soft/intel/idb/10.0.025/bin/iidb(_ZN7Session19parseCommandFromCinENS_4ModeE+0x155) [0x887074b]\n"
~"/usr/local/soft/intel/idb/10.0.025/bin/iidb() [0x889d19a]\n"
~"/usr/local/soft/intel/idb/10.0.025/bin/iidb(_Z15ProcessCommandsv+0x32) [0x889cb68]\n"
~"/usr/local/soft/intel/idb/10.0.025/bin/iidb() [0x889c746]\n"
~"/usr/local/soft/intel/idb/10.0.025/bin/iidb(_Z7idbMainiPPKcS1_+0x12b) [0x889c495]\n"
~"/usr/local/soft/intel/idb/10.0.025/bin/iidb(main+0x29) [0x87a32dd]\n"
~"/lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe6) [0x40381bd6]\n"
~"/usr/local/soft/intel/idb/10.0.025/bin/iidb(_ZStlsISt11char_traitsIcEERSt13basic_ostreamIcT_ES5_c+0x69) [0x83b7fe1]\n"
~"\n"
~"Intel Debugger for applications running on IA-32, Version 10.0-30 caught signal "Aborted" (6).\n"
~"[0x4001d400]\n"
~"[0x4001d430]\n"
~"/lib/tls/i686/cmov/libc.so.6(gsignal+0x51) [0x40395651]\n"
~"/lib/tls/i686/cmov/libc.so.6(abort+0x182) [0x40398a82]\n"
~"/usr/lib/libstdc++.so.5(+0x91c37) [0x40323c37]\n"
~"/usr/lib/libstdc++.so.5(+0x91b01) [0x40323b01]\n"
~"/lib/libgcc_s.so.1(+0x17ac2) [0x40363ac2]\n"
~"/lib/libgcc_s.so.1(_Unwind_RaiseException+0x11f) [0x40363e3f]\n"
~"/usr/lib/libstdc++.so.5(__cxa_throw+0x69) [0x40323dd9]\n"
~"/usr/local/soft/intel/idb/10.0.025/bin/iidb() [0x889baee]\n"
~"[0x4001d400]\n"
I will move this to the Linux section then.
