Community
cancel
Showing results for
Search instead for
Did you mean:
Intel 16 Giving #8763 warnings
Is this right?  Didn't have this problem with earlier versions....
data (arr(i),i=1,2) /-4.00e+00_dknd, -3.600e+00_dknd/
Steven_L_Intel1
We need a bit more context - ideally a small but complete program that shows the problem. Also, just giving the error number isn't sufficient - we need to see the actual and complete message.
Ok here's more detail
program main
   integer, parameter :: dknd  = selected_real_kind(15,307)   != 8-byte realkind
   real(dknd) arr(2)
end program
ifort ./main.f90  -stand f03
./main.f90(4): warning #8763: Fortran 2003 does not allow an expression as a DATA statement constant.
ifort 15.0.5.223 does not give the warning but ifort 16.0.3.210 give it.
This is on Linux
Steven_L_Intel1
Fascinating. Definitely a compiler bug. This is just a standards warning so you can either not specify -std or disable it with -diag-disable=8763
I will report this to development to be fixed in a future release. Issue ID DPD200412104.
Steven_L_Intel1
I expect this to be fixed in version 17.
