29348 Discussions
Intel Array visualizer/viewer with Visual Fortran Composer XE 2011
Samba_Ba1
Hello, I just started using the Visual Fortran Composer XE 2011 with VS2010.
It looks really great.
I wanted to visualize some arrays.
Do you know if it works with Array Visualizer/viewers?
By the way do you know what is the difference between visualizer and viewer?
Thanks in advance for you help and support.
I have used this combination successfully on IA-32. It does not work on 64-bit systems.
You want Array Visualizer - the Viewer is a subset that just allows you to run programs built using Array Visualizer and to view saved files. The Viewer does not include VS functions nor the ability to build programs.
