Using visual studio 2022 and the Intel Fortran Compiler Classic 2023.2.1, I created a new vc++ project that targets the vc11 (visual studio 2012) platform toolset. To my solution, i also added a new Fortran library project which i then linked to my vc++ project by:
- Specifying the directory containing my fortran library in Linker > General > Additional Library Directories
- Adding the library to Additional Dependencies
VCC directories:
- [include] $(IFORT_COMPILER23)compile\include;
- [library] ($IFORT_COMPILER23)compiler\lib\ia32_win; (and Intel64) when building 64 bit
With these settings:
- Use of MFC = Use MFC in a Shared DLL [vc++ proj setting]
- Runtime Library = Multi-Threaded Debug DLL [vc++ proj setting]
- Debug Multithread DLL [IFORT proj setting]
The Win32 debug build works fine.
If attempt to statically link MFC by changing:
- Use of MFC = Use MFC in a Static Library [vc++ proj setting]
- Runtime Library = Multi-Threaded Debug [vc++ proj setting]
- IFORT Runtime Library = Debug Multithreaded [IFORT proj setting]
I get a number of linker errors, such as:
- Error LNK2001 unresolved external symbol ___acrt_iob_func TestApp [...]\TestApp\libifcoremt.lib(for_diags_intel.obj) 1
- Severity Code Description Project File Line Suppression State
unresolved external symbol ___stdio_common_vfprintf TestApp [...]\TestApp\libifcoremt.lib(for_diags_intel.obj) 1 - [...]TestApp\TestApp\libifcoremt.lib(for_diags_intel.obj) 1
The same behaviour is observed when attempting to build the 64-bit version of the libraries, when statically linking.
I have tried adding /Qvc11 to the Fortran >> Command Line additional options in the fortran project.
I believe the unresolved external symbols are due to functions being removed from the universal CRT, which now reside in legacy_stdio_definitions.lib but as i am compiling against the VC11 platform toolset, I don't think i can include this library.
The project does build when i statically link and change the VC++ project to target the following toolsets:
- Visual Studio 2022 (V143)
- Visual Studio 2019 (V142)
- Visual Studio 2017 (V141)
- Visual Studio 2015 (V140)
Unfortunately, my project cannot be upgraded to a newer platform toolset at this time due to a heavily ingrained dependency. We currently build using Parallel Studio XE 2017.
I have attached a simple demonstration of the problem.
I have been able to work around the problem by copying certain libraries from the Parallel Studio XE 2017 installation on another machine into the OneAPI installation, for example:
- libifcore.lib
- libifcoremt.lib
- libirc.lib
- libircmt.lib
- libmmt.lib
I have attempted with the latest VS 2022 Preview and oneapi to compile your program. Once I fixed the target SDK - yours is very old and out of support, it asks for mylib.lib - how do you want me to link in the library that is in your system
