I nead a Intel EM64T Fortran 9.1 and Intel EM64T C++ 9.1compiler. I searched it in intel site but its not avialable here so how i can have ?
You will want to go to https://registrationcenter.intel.com
Use the 'registered user', and then use your email address and password that you set up when you registered your product. Once logged in, you will see the most recent version that you are entitled to (which depends on your support status) under the "Downloads" column. For example "10.1 (014)". This version number is hyperlinked. Click it. The second page you get to has pull down menus to select previous compilers, including 9.1.
ron
ron
Thanks for your reply but there i am not geting EM64T Fortran 9.1. any where else i can have this????
In version 9.1, there is not a separate EM64T download. You download the full compiler product and when you install it on an x64 system, you'll get the EM64T compiler.
https://registrationcenter.intel.com is the only place where we put compilers for download.
The package names are l_fc_c_9.1.052.tar.gz for the Fortran compiler, and l_cc_c_9.1.052.tar.gz for the C++ compiler.
I downloaded l_cc_c_9.1.052.tar.gz for the C++ compiler .its serial no. is and license file is NCOM_L_CMP_CPP_.lic but when i am instaling it giving error as invalid serial no. and invalid license file. PLZ suggest how i can instal it? previously i downloaded 10.1 version and instaled ,at that time it was not giving error relatedf to license file and serial no.So is it a problum with this version?
Please do not post serial numbers in the forum.
That serial number is for the Fortran compiler only - it is not valid for the C++ compiler. The license file you gave the name of should be valid for the C++ compiler. Save that license file to disk and when you install the C++ compiler, select the option to "browse for a license file" and point to the saved file.
I will remember that. Now i am doing instalation of fortran compiler by using it license file and serial no. but still i am geting same error. What should i do now?
You cannot install the 9.1 compiler with the 10.1 serial number. The license file that accompanied the Fortran serial number should work to install Fortran. If you don't have it, you can log into the Intel Registration Center and ask that the license file be emailed to you.
I suggest going to the Intel Registration Center Help page and use the "Chat" feature to talk to one of our startup support specialists.
I need " Intel Fortran 10.1 EM64T compiler, I logged into intel support and went to this page: https://registrationcenter.intel.com/RegCenter/Download.aspx?productid=988
But I cannot find the " Intel Fortran 10.1 EM64T compiler", there are options for IA-32 and IA-64 but nothing about EM64T, Would you please help me on this.
It is now called "Intel 64".
